Twin disk brake GSX 1100 G
tommivx
Beitrag von tommivx »
I'm italian, I can't speak german...so I dont know if you are talked about this somwhere else. I'd like to improove the vx800's breake system, by using a gsx 1100 g front fork-weel-brake system. is it possible?
thanks
tom
starfly
Beitrag von starfly »
I think u will have to wait for someone, who has realized this change in breaking system...
We`ve got 1 or 2 Members with changed Forkes...
ingodererste
Beitrag von ingodererste »
Hi!
If it's your only aim to improve the break system you can use the fork from a CBR1000, too. The description of the change you can find here:
http://www.geocities.com/leuzi3/
Cheers, Ingo
Viele Grüße,
Ingo
tommivx
Hi, thanks for the link, interesting! but I'dont like to change the color of the wheel and the fork is black...
Should be cool to change the gsx 1100 g fork..any idea?the problem is found one...
:twisted:
StephanCDI
Beitrag von StephanCDI »
Well, what's the problem by painting the new wheel in the colour of your favour? Think that would be the lower hurdle than finding the one and special fork in your preferred colouring. :wink:
Hans Friedrich
Beitrag von Hans Friedrich »
The diameter of die VX-800-fork is different to the diameter of the GSX-1100-G fork. This means, that you have change the Topbridge and the Stearing Stem too. Take a look at the Frontframe of the two Bikes, if the height is the same and also the bearings, you will have the best-braking-VX ever seen!
P.S.: Sorry for my english, i hope you're able to tranlate it into your own language.
tommivx
are you sure?
I dont'find the mesures... could you find the fork diameter of vx and gsx? I see many german's sites...
thanks so much.
:P
Hans Friedrich
VX 800: 41 mm
GSX 1100 G: 43 mm
tommivx
mh...
so, I found a gsx's fork at 300 euros.. but what's the diameter of the steering? are u sure that's different?
Beitrag von Joerg#1 »
Yes. Look at the last topic from Hans Friedrich. You have to change the complete fork! And You need also the front master zylinder (breake) from the gsx, for two disks.
tommivx
cool! your vx is cool! but the front wheel isnt a 18"...so is not regular!? it's 17"? from how does it come for?
tommivx
I've foud this one...
is it right?
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=350174371100&ih=022&category=89466&_trksid=p4340.m7&_trkparms=algo%3DLVI%26its%3DI%252BC%252BS%252BIA%26itu%3DUCI%252BUS-BWR%26otn%3D3%26ps%3D57
tommivx
Here the GSXG double disk and fork
http://vxdefrance.xooit.fr/t1042-Modif-train-avant.htm?start=15
[url]http://img74.xooimage.com/views/3/7/0/imag0057-320e95d.jpg/[/url]
Beitrag von Frank_#62 »
Ciao Tom,
molto bello :)
Spero che ci vedremo a [url=http://translate.googleusercontent.com/translate_c?rurl=translate.google.com&sl=de&tl=it&u=http://www.vx800-weekend.de/&usg=ALkJrhgtKQjO6wViucJmwVZANStdqQg4IA]Goslar.[/url]
Frank
tommivx
Here many others pics.
The VX still not ride because of the brake system...(I need to fix the caliper's pistons)
Anyway I hope that will be easy to handle and not too heavy...
http://vxdefrance.xooit.fr/t1042-Modif-train-avant.htm?start=30#p11800
tommivx
Finally:
a vx 800 with gsxg's fork and double disk:-)
http://vxdefrance.xooit.fr/t1042-Modif-train-avant.htm?start=30#p11834
:shock: :shock: :shock: :shock:
